style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
On that machine, start the match properties command, select an object,
then type S (for Settings) and enter. Is the Hatch toggle in the Special
Properties area at the bottom checked? If not, check it and it should work for
hatches.
David Koch
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Here
is an even less likely cause: are you using the same "source" hatch for your
tests on all three machines? A hatch originally created in a sufficiently old
drawing (I forget which version) will not have the hatch pattern and other
data stored with it, so it will not be able to be copied (or serve as the
source for an inherit properties attempt from the Boundary Hatch dialog).
David Koch
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
"Jerry Logan" <cad@bhharchitecture> wrote in message
href="news:4A7DB98495F70830E6DE6164AB78F230@in.WebX.maYIadrTaRb">news:4A7DB98495F70830E6DE6164AB7......
David,
That didn't do the trick either. That was
pretty obscure. I'm still looking for an answer if anyone has
one.
Thanks David keep em coming
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">Here
old drawing (I forget which version) will not have the hatch pattern and
other data stored with it, so it will not be able to be copied (or serve as
the source for an inherit properties attempt from the Boundary Hatch
dialog).
David Koch
The hatch pattern file is on the server and the
problem machine was not pathed to that location in the support file search
paths.
