The relationship between color and lineweight is set up in accordance with the TriServices plotting standards, which is part of the US National CAD Standard.
Colors 1-9 [black, but pattern varies from standard] and 250-255 [black, halftones] vary, but the basic arrangement of the other colors is in groups of ten, which alternate between black/screened black [odd tens] and various colors [even tens]. Each group of ten is assigned lineweights based on the last digit of the number as noted below:
0 - 0.18 mm [Fine]
1 - 0.25 mm [Thin]
2 - 0.35 mm [Medium]
3 - 0.50 mm [Wide]
4 - 0.70 mm [Extra Wide]
5 - 1.00 mm [Moderate Bold]
6 - 1.40 mm [Bold]
7 - 0.35 mm [Medium] <-- Halftone when color is black
8 - 0.70 mm [Extra Wide] <-- Halftone when color is black
9 - 2.00 mm [Extra Bold]
If I recall, the colors used by ADT ignore the color pen assignments in the TriServices guidelines and use Black/Screened black for all [monochrome plot styles].
David Koch
Autodesk Discussion Group Facilitator
