I have no idea why certain lines do not get converted. As I said, in some
cases it is possible to add additional mullions to the assembly, but that
can be tricky. You might want to try various arrangements of your lines and
see if it makes any difference. And try breaking lines at intersections.
If your assembly is a simple "L" shape, you might want to try using a
standard rectangular assembly style and using cell overrides to remove the
cells from one corner. This could give you the same affect,
If you're still having trouble, you might want to post the file.
Paul Gold
Autodesk Authorized Independent AEC Consultant
PAUL GOLD CONSULTING
New York, NY
(212) 595-0171
paul.gold@att.net
"phani kumar"
wrote in message
news:E2A7E37CB802DB1C911DD6471ACA5DAE@in.WebX.maYIadrTaRb...
> The problem is I am trying to create an assembly. When I select the
> line-work, an Assembly is created, but with few mullions missing. The
> line-work is there, but does not get converted.
> Thanx
> Phani
> "Paul Gold" wrote in message
> news:3BD046CB98D3171ADA61A3795353C98A@in.WebX.maYIadrTaRb...
> | Phani,
> | You can not add mullions to the "Custom Grid" level of the assembly, but
> you
> | can add a new "nested grid", with mullions, to individual cells. If
there
> | are only a few mullions missing, this might be a feasible method, but if
> | there are a lot missing, it might be easier to start over again.
> | Paul Gold
> | New York, NY
> | (212) 595-0171
> | paul.gold@att.net
> | "phani kumar" wrote in message
> | news:3E48017D6160F42E9EBC99AD65EE3B2E@in.WebX.maYIadrTaRb...
> | > I have an L-Shaped window. I have drawn lines & used the "Convert
> Linework
> | > to Window Assembly".
> | > But some mullions get left out from getting created. Why? & How do I
add
> | > mullions to the Window assembly??
> | > Thanx for any help.
> | > Phani Kumar
