no, they have dis rep for both rcp and plan. Depending on how your system is
setup you may need to modify the display setting for RCP in the display
manger, but it should work. Just check the override boxes for the DR you
want to change.
wrote in message news:6032743@discussion.autodesk.com...
Correct me if I'm wrong, but the AEC Polygon doesn't have Display Props for
Reflected or Plan, just Model. It will look the same in both display reps,
which we don't want.
