Are you using any custom VBA routines during startup? If so, disable or
remove them. If the error goes away, then you know the problem is with the
coding, and most likely has to do with the AcStandards command call.
Anthony
Building Industry Division Product Support, Americas
Visit us at: http://www.autodesk.com/support
"David Hogan" wrote in message
news:5B092C17C3F94F7FA9DA47491A1966DC@in.WebX.maYIadrTaRb...
> "Initializing VBA System...Error loading AcStandards services" What's
> causing this? Is it a known problem?
