Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Error code 0x2 The system cannot find the file specified.
2 REPLIES 2
3960 Views, 2 Replies
I have just installed ADT 3 and get the following error messsage.
Error code (0x2) The system cannot find the file specified.
AcRxDynamicLinker failed to load 'C:\Program Files\Common Files\Autodesk
Shared\AeclSD.dbx'
C:\PROGRAM FILES\AUTODESK ARCHITECTURAL DESKTOP 3\ACAD.EXE
ERROR: AecLoader could not load requested module "C:\Program Files\Common
Files\Autodesk Shared\AecStructureBase30.dbx".
Any suggestions to fix are welcome. Thanks.
2 REPLIES 2
Did you reboot after you installed? We add the c:\Program Files\Common
Files\Autodesk Shared directory to your PATH during the install.
If that doesn't do it for you, let me know.
Scott
"Steve Kay" wrote in message
news:CB24711AC25301C08034CEBAC05E712A@in.WebX.maYIadrTaRb...
> Shared\AeclSD.dbx'
BrandtBolding
RE: ERROR: AecLoader could not load requested module "C:\Program Files\Common
I installed ADT3 on a W98/385m that previously had ADT2i and I get these same error messages. I have tried reinstalling fully several times and also using the couple of repair reinstall options - no success - I still get these error messages. I don't quite understand your suggestion about the "path" option you mentioned in you reply. I would appreciate any help.
