Did you reboot after you installed? We add the c:\Program Files\Common
Files\Autodesk Shared directory to your PATH during the install.
If that doesn't do it for you, let me know.
Scott
"Steve Kay" wrote in message
news:CB24711AC25301C08034CEBAC05E712A@in.WebX.maYIadrTaRb...
> I have just installed ADT 3 and get the following error messsage.
> Error code (0x2) The system cannot find the file specified.
> AcRxDynamicLinker failed to load 'C:\Program Files\Common Files\Autodesk
> Shared\AeclSD.dbx'
> C:\PROGRAM FILES\AUTODESK ARCHITECTURAL DESKTOP 3\ACAD.EXE
> ERROR: AecLoader could not load requested module "C:\Program Files\Common
> Files\Autodesk Shared\AecStructureBase30.dbx".
> Any suggestions to fix are welcome. Thanks.
