Mike,
Please see my post dated 8/1/2001 4:15PM for my response.
Essentially the message is harmless... and is logged for future repair
mark webb
software engineer
building industry division, autodesk
"mike maness" wrote in message
news:4AA26267A4A119673094CF10950C8927@in.WebX.maYIadrTaRb...
> i have posted this before but no hits so i'll try again. whenever i use
the
> layer manager to edit the layer standards when i close the dialog box down
i
> get the message "cannot find the resource string 11717 (at times several
> different numbers are displayed) in resource aecuibase" i don't know if
> this is creating any problems or not but i would like to know what this
> means.
> David Claflin wrote in message
> news:ACC6A9C864D8B15FA01539040CC4014E@in.WebX.maYIadrTaRb...
> > I did not receive any bites in the content newsgroup, so I am reposting
> > here. Any takers?
> > David
> > I agree, the tutorial was good and the steps Autodesk makes you go
through
> > are convoluted.
> > I tried using this process to make a window assembly with a double door
> (6'
> > w x 7' h) with sidelights (3' w x 6' h). The door in plan view offsets
> > itself approx 3' from the insertion point, but breaks the wall as if it
> > wasn't offset. In an orbited view the opening aligns with the door.
Has
> > anyone seen this problem??
> > David Claflin
> > P.S. Drawing file in C.F. as ADT drawing.dwg
> > "nlnaia" wrote in message
> > news:f068769.2@WebX.maYIadrTaRb...
> > AMEN Daniel, meanwhile thanks Bret. Nevine
