Ahh, the command line.
I wish I could use the command line for 'section' and 'elevation' too.
"Dennis McNeal, AIA - Autodesk BSD"
wrote in message news:4145f19b_2@newsprd01...
> Hmm....it's working for me here. After selecting the tube from DCM,
setting
> the view to Elevation in Property Palette I was able to use the Center
> option from the command line w/o problem. Are those the steps you used?
> Thanks,
> Dennis
> Dennis McNeal, AIA
> Autodesk BSD
> "F. Gump" wrote in message
news:4145e5cf$1_1@newsprd01...
> > ADT 2005, I want to draw a tube steel x-brace detail.
> > I would like to draw the tube steel in elevation view with the center of
> > steel aligning with a workpoint, but the detail component manager does
not
> > allow me the "center" option once I select elevation.
