Autodesk Architectural Desktop 2007 & Prior
*Caruthers, Paul
Message 1 of 4 (209 Views)
DETAILS (MENU)
209 Views, 3 Replies
11-16-2003 10:16 PM
Is there a easy one-step way to change the size (physical dimensions) of
some of the detail items..for instance the 6" batt insulation doesn't fit in
a 2x6 stud wall (it's only 5 1/2" wide) and will run into either the
sheathing or the drywall.
Paul Caruthers
*Alvarez, Rafael
Message 2 of 4 (209 Views)
Re: DETAILS (MENU)
11-17-2003 12:54 AM in reply to: *Caruthers, Paul
Edit the AecMaterials.mdb with Microsoft Access. There are default tables in
which you can edit the widths and even add more choices, etc. It is located
in the following directory:
C:\Documents and Settings\All Users\Application Data\Autodesk\Autodesk
Architectural Desktop 2004\R16.0\enu\Support\AecDetails
*Caruthers, Paul
Message 3 of 4 (209 Views)
Re:
11-17-2003 01:12 AM in reply to: *Caruthers, Paul
AWSOME. THANK YOU---
"Rafael Alvarez" wrote in message
news:5996DE578A287E5943578C59FF1361A3@in.WebX.maYIadrTaRb...
in
located
Member
Tapp_Joshua
Message 4 of 4 (190 Views)
Re: DETAILS (MENU)
05-28-2012 09:42 AM in reply to: *Caruthers, Paul
Rehashing old stuff here:
I'm back on my own for now and have ADT 2004.  I would like to edit the AECMaterials.mdb file to add in proper batt insulation sizes.
I don't have MS Access, so instead I downloaded Open Office and am trying to edit it there.  I can see the 07-BATT-I table, can see the sizes, but can't seem to do anything with them.  I can't add, edit or do anything else except change the order in which I'm viewing them.
Any suggestions?
Joshua Tapp
Joshua Tapp
You are not logged in.
Ask the Community
