Autodesk Architectural Desktop 2007 & Prior
*Branch, S.
Message 1 of 8 (73 Views)
Custom Structural Profile
73 Views, 7 Replies
09-05-2001 03:11 AM
I'm creating a trellis....simple.
The trellis members are Structural Members (4x10). This is great because of
the flexibility in the various display configurations. I like using ADT3's
structural members for that reason...
HOWEVER, I now need to create a custom, spanish 'end-cut' for the trellis
cross members. Is it possible to assign a 'profile' to the ends of my 4x10
to make the shape? This task would be easy enough using solids &
conventional solid modeling, but then I would lose the versatility of the
display properties of the structural member.
Help?
Scott.
*mark webb, autodesk
Message 2 of 8 (73 Views)
Re: Custom Structural Profile
09-05-2001 03:36 AM in reply to: *Branch, S.
Not being an architect or a horticultural type, I'm not sure what this looks
like. Can you send me a quick sketch/photo/link/diagram to
mark.webb@autodesk.com and I'll let you know if and how the results can be
achieved...
regards
mark webb
software engineer
building industry division, autodesk inc
"S. Branch" wrote in message
news:smileyvery-happy:C31125EFB2BD651C799A593E28DE758@in.WebX.maYIadrTaRb...
of
4x10
> Help?
> Scott.
Message 3 of 8 (73 Views)
Re:
09-05-2001 07:13 AM in reply to: *Branch, S.
Thanks for you email.. Dennis McNeal also stopped by and explained what this
all meant ;-)
(I knew I should have just asked someone here..)
Anyway, I was able to achieve this with Custom Blocks attached to either end
of the Member Styles display properties
To view this check out my posting in the content newsgroup.
1) edit the "Trellis" member style
2) select the Display Properties tab
3) select the Structural Member Style line then "Edit Display Props..."
4) Go to the edit page, and you will see a custom block definition for each
end of the trellis
Hope this helps
mark webb
software engineer
*Branch, S.
Message 4 of 8 (73 Views)
Structural Beam Trim Planes
09-06-2001 04:36 AM in reply to: *Branch, S.
When I insert a trim plane to a beam end, and rotate it around the Z axis,
it only rotates one half of the beam. In other words, it only rotates on one
side of the centerline axis of the beam.
___________________
|__________________ this winds up looking
__________________
\_________________ like this
Scott.
*Gold, Paul
Message 5 of 8 (73 Views)
09-06-2001 05:05 AM in reply to: *Branch, S.
Try giving it an X offset as well.
Paul Gold
PAUL GOLD CONSULTING
New York, NY
(212) 595-0171
paul.gold@att.net
news:B48800538FC2A42109B6F3E9F9EBFE66@in.WebX.maYIadrTaRb...
one
> ___________________
> __________________
> Scott.
Member
vtrammell
Message 6 of 8 (73 Views)
Re:
02-19-2002 03:29 AM in reply to: *Branch, S.
Hi, I have been trying to figure out how to achieve a beam end similar to the one in this posting, but I can't seem to find your posting in the content news group. Could you please tell me how to view that posting?
VTrammell
Distinguished Contributor cbc
cbc
Message 7 of 8 (73 Views)
02-19-2002 03:44 AM in reply to: *Branch, S.
A COUPLE OF OTHER APPROACHES MIGHT BE:
1. MAKE AN AECPROFILE FROM A POLYLINE
OF THE DESIRED SPANISH-END SHAPE AND THEN CREATE A MASS
ELEMENT USING "EXTRUSION"
2. USE TRADITIONAL SOLIDS EDITING THEN USE "AECMASSELEMENT
CONVERT" TO CREATE A MASS ELEMENT.
TRUE STRUCTURAL MEMBER TECHNIQUE W/ CUSTOM BLOCK IS PROBABLY
BETTER OR AT LEAST MORE "PRESCRIBED" ADT METHOD.
cbc
David_W._Koch
Message 8 of 8 (73 Views)
Re:
02-19-2002 06:49 AM in reply to: *Branch, S.
The post is from September 5, 2001, which is beyond the three-month cutoff on the web-based access. Try doing a search of the customer files news group, but change the "last 3 months" setting to "all" and search for the title listed in Mr. Webb's response.
David Koch
You are not logged in.
Ask the Community
