We wish to show a curtain wall in plan with mullions and frames of 50x100mm, glass of 20mm in the middle of the frame and then the bottom of the frame running along the outer edge of the the frame (similar to a window).
The Cut plane is 1400mm and the glazing is 3500mm high.
To get this effect i have to reduce the hight of the glassing to 1450mm so it shows the lines.
Any idea how to get it to show the frame edge and keep the highest of the glazing correct.
It has to be the cut plane, but I cannot figurer out where it is in the settings.
Thank you
