I believe you would have two choices. If it has to be a window style, then you will need custom blocks to replace the standard display components. If it can be a curtain wall, you can get curved panels by referencing a "curve", which can be (but need not be) an arc or curved polyline.
David Koch
Member of the Autodesk Discussion Forum Moderator Program
