No setting. But as David indicated, the order is important.
Paul McArdle
"David_W._Koch" wrote in message
news:3121615.1077211899969.JavaMail.jive@jiveforum2.autodesk.com...
> I have not used the Project Management system enough to be certain this
will help your situation, but you may want to check out the following
thread, which contains a post from Paul Aubin outlining the steps to take
when copying/renaming a project:
> http://discussion.autodesk.com/thread.jspa?messageID=1870130
> If you are already doing all of that, someone else will have to weigh in
with a response.
> David Koch
> Member of the Autodesk Discussion Forum Moderator Program
