A trick that I both learned and taught on the fly in a class I had a little
while ago, is that you can effectively "add" vertices to an existing space
through the "space merge" command. Simply add another generic space to the
original one, and make sure that they overlap. Then pick on the original
space, right-click and use the "join" option and then pick the new space.
Because you started with the existing space object, all of your schedule
data remains intact. You now have 2 or more new vertices that you can mess
with in your space object.
Not a direct process, but it can be faster than re-creating the space all
over again...
As to the message from Brian down below... It may be possible (just thinking
aloud here) to use the "sketch" representation of your walls to generate the
spaces in a design... Its effectiveness would depend on what justification
you used to insert your walls, but it is a possibility. It could be that the
bpoly command will not recognize the sketch rep of a wall. Again, just
thinking on the keyboard here.... If I get a chance I will try it out, but
that may not come for a while.
Joe Eichenseer
Senior Architectural Specialist
Avatech Solutions
Denver, CO
jeichenseer@avat.com
"Matt Dillon" wrote in message
news:4E2989C5C012A427D0753FC65AD13947@in.WebX.SaUCah8kaAW...
> Brian,
> I used to do quite a bit of area calculations to BOMA standards. It was
long
> before ADT, but I suspect I would do it the same way now.
> Since there isn't the intelligence necessary to determine for each wall
> where the demising line should be, and in some cases it may vary along the
> wall depending upon what is on the other side of the wall, I would
> recommend creating the polylines according to BOMA standards and
generating
> the spaces from them. If the space changes, you can grip edit the space
> object to adjust, as long as there are no new vertices that need to be
> added. If new vertices become necessary, you'll need to recreate the
> polyline (or PEDIT the original) and regenerate the spaces from the new
> geometry.
> Please do not send technical requests to me via private email
> Matt Dillon
> Assistant Moderator, Autodesk Discussion Groups
> http://www.dccadd.com
> Brian Harder wrote in message
> news:88A9E9758C1982BD86DE25FB677775F0@in.WebX.SaUCah8kaAW...
> > Curiosity question: How have others been dealing with the BOMA standard
> > that says that areas should be measured to center of demising walls?
> > Manually stretching the plines or objects?
> > Brian K. Harder
> > CAD Manager
> > RNL DESIGN
