IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
2242 Views, 5 Replies
CAD blocks
where can one find a block for Bleachers?
5 REPLIES 5
If stairs wont do -- I suggest you re-post with the topic. "need bleachers" -- I would guess someone has made a stair style, wall style, etc. before. Or you might build one row from solids or mass elements and ARRAY at an angle.
It is possible that bleacher manufacturers have CAD drawings or blocks.
BOB
> BOB
I went overboard on one job... Here's a curtainwall style I've used.
It was hacked together pretty quick, so it isn't perfect.
To make it *really* work right, you need to override the cut plane on
every row of seats... I just sketched the remainder of the plan with
lines instead...
Brian Winterscheidt
LWPB Architects & Planners, P.C.
Oklahoma City, Oklahoma
I am just amazed that people are able to build such complicated objects with this software.
Hats off to you.
Sir, I have been studing you bleacher1 drawing for a week now and can not figure out how you change the aisle location when I need a 88 foot wide bleacher vs your 51' could you please help.
thank you
Byron
bdchristian@cox.net
> thank you
> Byron
> bdchristian@cox.net
I think your best bet would be to start with a new CW object that has no
infill overrides--don't try to modify the objects I have already
created. From there, you can turn on the infill markers, merge cells,
and override infills as needed to produce the design you need.
Brian Winterscheidt
LWPB Architecture
