IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Building Systems 3 OE setup error.
2 REPLIES 2
94 Views, 2 Replies
Hi folks,
I've started recieving drawings from a consultant made using Autodesk
Building Systems 3. We're trying to open them in ADT3.3 SP2 and it ain't
happening.
So, I attempted to install the OE for ABS3 and I get the following error
message...
"Autodesk Building Systems 3 Object Enabler is not compatible with the
version of AEC ObjectDBX currently installed on this machine.
Please remove any older Object Enablers or update installed products."
The problem is that I did just that and removed an OE that was installed and
also made sure sp2 was installed. AutoCAD 14 had also been installed on that
computer so I removed that to be safe. Still no luck. It won't even allow me
to re-install the OE that had been on there before.
Thanks for your input,
Jim Bednarz
IT Administrator/ CAD manager
2 REPLIES 2
Did you happen to have Adt2i on the machine at one point?
James Bednarz wrote:
> Hi folks,
> happening.
> message...
> Jim Bednarz
No, I don't think so.
"Mike Hutchinson" wrote in message
news:3EF1F88B.E045334B@bbsae.com...
> > Hi folks,
> > happening.
error
> > message...
and
that
allow me
> > Jim Bednarz
