• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Architectural Desktop 2007 & Prior
    Distinguished Contributor
    Binding Xrefs, Walls Disappear???
    71 Views, 7 Replies
    09-24-2001 01:24 AM
    This message refers to ADT2i, but no one is replying there...so I ask for your comments here. With over 1400 topics here, I am sure you are busier than in the ADT2i group with only 198 topics.
    I am binding some Xrefs to a Parent dwg file. Indiscriminately, some wall objects just disappear. They don't show in Model or Paper Space. And even though I have the same plan in 2 different Parent files, different wall objects disappear in each file when Bound.... So, what is the work-around/fix for this??? Or, is it just another one of those fun things that are quirky about using Desktop.... Thanks, Wesley
    Please use plain text.
    *Sinclair, Michael
    Re: Binding Xrefs, Walls Disappear???
    09-24-2001 03:10 AM in reply to: wessargent
    I would first check to see which display
    representation set is set current. ie: work, work reflected, all,
    standard...etc.
    Michael Sinclair
    innerspace studios ltd.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    This
    Re:
    09-24-2001 03:29 AM in reply to: wessargent
    What difference would that make, either the walls show up or they don't depending on the display selected....They don't say...some walls display, others don't in this particular display. I need more information in order to put your advice to work.
    thanks,
    *Autodesk\
    09-24-2001 04:35 AM in reply to: wessargent
    There is a known problem with some walls with
    anchored objects. To verify that this is what is going on, you
    can unanchor the entities attached to the walls disappearing (in the
    xref file) and then do the bind. If the bind works, reanchor the objects to the
    walls.
    If that does fix it, can you post the drawing and
    let us know which walls disappear?
    Scott
    This
    *Autodesk, Dennis McNeal -
    09-24-2001 04:52 AM in reply to: wessargent
    Wesley,
    Are all files in ADT2i format?
    Have you tried auditing or recovering all
    files involved prior to binding?
    Do you get the same results if you detach the xref
    & insert?
    Are you experiencing any other graphics
    problems?
    Dennis McNeal
    Building Industry Division
    This
    *Dillon, Matt
    09-24-2001 04:58 AM in reply to: wessargent
    Do you get any defect markers when they dissappear?
    Please do not email me privately with technical issues
    Matt Dillon
    Assistant Moderator: Autodesk Discussion Forums
    http://www.dccadd.com
    "wessargent" wrote in message
    news:f083267.-1@WebX.maYIadrTaRb...
    Re:
    09-24-2001 05:11 AM in reply to: wessargent
    no defect markers...I will try the other things mentioned...but, I doubt I will have time to really research it...
    Active Member
    09-30-2001 05:26 PM in reply to: wessargent
    We also have found object data missing when binding Xrefs, mainly walls but sometimes also spaces. This has affected ADT3 as well as ADT2i.
    As a work around we have either wblocked all information out of the base drawing or generally use "copy , delete and paste to original coords" in the same base drawing. This recreates the objects and seems to resolves the problem when binding.
    However, I would also like to know wahat causes the initial fault.
    Paul
