IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Assign Multiple Tags at Once
3 REPLIES 3
696 Views, 3 Replies
We have our spaces set up. Is there a way to add all the room tags at once? Thanks...John
3 REPLIES 3
David_W_Koch
Tag the first Space, then use the Multiple option (look at the prompt on the command line) and select all of the Spaces to which you want add tags.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Thanks David...
in reply to: David_W_Koch
Thanks for that to the point answer.Smiley Happy
A half hour of searching "help" netted me not a clue on how to do this.Smiley Mad
Really a simple search "tag multiple spaces" Should get you to somewhere that tells you how to tag multiples spaces. Instead the frist result is for Attribute Definition Dailog Box, which has nothing to do with tagging spaces. Please somebody fix the help indexes before it too late!
