• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Architectural Desktop 2007 & Prior
    Active Contributor
    Annotation Plot Size - 3/32"?
    154 Views, 3 Replies
    10-03-2000 07:39 AM
    In our office we typically set out text height at 3/32". So in an 1/8" drawing our text is 9" high. My problem is with some of the tags. When I set my drawing scale to 1/8" it won't let me set the anno plot size to 3/32". It will only allow 1/16 or 1/8. Anyone have any ideas on how to get my tags to plot out at 3/32?
    Please use plain text.
    *Support, Tony - Americas Product
    Re: Annotation Plot Size - 3/32"?
    10-03-2000 09:06 AM in reply to: JasonO
    It sounds like linear precision is set to 1/16" instead of 1/32". From the Desktop menu, choose Drawing Setup and under the Units
    tab check the linear precision setting. If you want to use an annotation plot size of 3/32", then your linear precision must be at
    1/32" or lower.
    Tony
    Discussion Moderator
    WW Support & Services, Autodesk
    Discussion Q&A: http://discussion.autodesk.com
    "JasonO" wrote in message news:ef47cf4.-1@WebX.SaUCah8kaAW...
    Active Contributor
    Re:
    10-03-2000 10:04 AM in reply to: JasonO
    Thank you, Thank you
    I knew it had to be something simple like that.
    Jason
    HAMJAM
    Re: Re:
    09-05-2011 02:05 PM in reply to: JasonO
    yep; thanks your solution worked for me too!
