Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
75ironhead
2894 Views, 1 Reply
AcDbZombieObject?
Not sure what happened here but when i try to define a block then try to edit it in this dwg i get this response at the command line. i thought it was kind of comical at first but it's getting a little irritating .
has any one encounter this before?
Command: _.refedit Select reference: 5.164279,6372.223729,0.000000
I forgot to add this, it also came in on the command line.
Command: _.refedit Select reference: 3673.953285,6239.697052,0.000000
Errors found in references to other objects:
** Application reference missing: AcDbBlockRepETag, to AcDbPolyline.
** AcDbZombieObject objects cannot be referenced. Message was edited by: chevelle
1 REPLY 1
in reply to: 75ironhead
I am getting the same error while editing an xref in place.
As a work around, remove the editted linework from the working set then discard the changes to the xref. Open the xref rather than editting in place and copy paste the revised linework back into the xref. Its a bit of a pain but better than losing your changes. Some feedback from Autodesk would be appreciated as it seems to be a common issue.
