Autodesk Architectural Desktop 2007 & Prior
Distinguished Contributor
terencechatfielduk
Message 1 of 3 (537 Views)
ARX_ERROR: eLockConflict
537 Views, 2 Replies
02-22-2005 09:40 AM
OK, the number of times that the above error has crashed me out so far this year is getting excessive.
Full error message below, from one of the few times I've been able to escape out of it:
Document "G:\6214 Farthingloe Great Farm\2_Planning\Models\SX01.dwg" has a
command in progress.
Hit enter to cancel or [Retry]: *Cancel*
Is there a hot fix about this from Autodesk? By now there bl**dy well should be.
BTW, when this crashes ADT now error reporting sequence is generated, so nix on the feedback via that way to the development team.
Vitornis
Message 2 of 3 (474 Views)
Re: ARX_ERROR: eLockConflict
09-28-2012 09:05 AM in reply to: terencechatfielduk
Im having problem with this error with MEP 2011.
New Member
bearsley
Message 3 of 3 (187 Views)
02-25-2014 06:57 AM in reply to: terencechatfielduk
quickly pressing "Esc" key multiple times (8-10x) will exit this error mode and return to normal command prompt. this error occured for me during a plot "pick window" when a tool pallet flyout was activated. i'm surprised Autodesk has not posted a readily accessible fix or work around for this known common issue. i have supported muliple users over the years with this same issue.
You are not logged in.
Ask the Community
