• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Architectural Desktop 2007 & Prior
    *Mochrie, Craig
    AEC crashes ADT 3.3 and ADT 2i
    95 Views, 11 Replies
    01-31-2003 03:13 PM
    I have upgraded OS to XP Pro and have installed ADT2i and then trial of
    ADT3.3 Neither program will allow use of AEC objects or dwg templates, I
    get a Fatal Error; Attempt to delete AecDatabaseData which still has
    registered dependants.
    The menu line says could not load requested module "C:\Program Files\Common
    Files\Autodesk Shared\AecBase20.dbx".
    I cannot open any existing drawings that contain Aec Objects.
    Please assist.
    Craig.
    Please use plain text.
    *Medina, Alfredo
    Re: AEC crashes ADT 3.3 and ADT 2i
    01-31-2003 09:07 PM in reply to: *Mochrie, Craig
    Crag,
    Run a reinstallation of ADT. Select the option named as "Repair AEC loading
    mechanism". That might fix the problem.
    Alfredo Medina
    "Craig Mochrie" wrote in message
    news:2283A08792DDC7221F760C0F8C2E2B51@in.WebX.maYIadrTaRb...
    *Bromell, Paul
    02-01-2003 01:57 AM in reply to: *Mochrie, Craig
    Someone please correct me if I'm wrong because I don't know for sure but I
    don't believe that those 2 programs can co-exist on the same drive/machine.
    A search through these newsgroups should yield an answer to that.
    Paul Bromell - Metalstuff
    Files\Common
    > Please assist.
    > Craig.
    *Mochrie, Craig
    Re:
    02-01-2003 10:49 AM in reply to: *Mochrie, Craig
    Alfred,
    Thank you for the suggestion. I reinstalled ADT2i and can now use the
    metric aec template, however no AEC applications are loaded. I could not
    find the Repair AEC loading mechanism option, is this in ADT 3.3 only? If I
    load AecData.dbx by manually looking for the file, same error about
    dependants comes up and it crashes again. Also on loading I get a error
    that the shortcut has a bad profile in the ADT.arg and that the one in the
    registry will be substituted.
    Craig.
    *Medina, Alfredo
    Re:
    02-02-2003 12:33 AM in reply to: *Mochrie, Craig
    Craig,
    Yes, that option is in the ADT3.3 installation CD. Also, I think the problem might be
    caused for trying to have ADT2i and ADT3.3 installed in the same machine. Why don't
    you just leave one version?
    Alfredo Medina
    news:FD3F01D444E2D2A1EFA239B409245581@in.WebX.maYIadrTaRb...
    > Alfred,
    > find the Repair AEC loading mechanism option, is this in ADT 3.3 only?(...)
    *Mochrie, Craig
    Re:
    02-02-2003 07:34 AM in reply to: *Mochrie, Craig
    Alfredo,
    I have only ADT2i on the machine at present. I would like to be able to go
    back to a fully functioning 2i before I load 3.3 again. I am reluctant to
    try 3.3 again until I,( with the assistance of people like yourself), have
    repaired the problem. I would like to know what caused the error in the
    first place.
    *Medina, Alfredo
    Re:
    02-02-2003 10:51 AM in reply to: *Mochrie, Craig
    Craig,
    The problem might have been caused when you tried to have the two programs
    simultaneously. I understand that these two versions cannot coexist in the same
    system.
    Alfredo
    news:C453FE78FFAEE9F172B6568363C27713@in.WebX.maYIadrTaRb...
    > Alfredo,
    > first place.
    *Mochrie, Craig
    Re:
    02-02-2003 01:30 PM in reply to: *Mochrie, Craig
    Alfredo,
    I think you are right, I should not have installed 3.3 with 2, however 3.3
    and 2i are supposed to be able to coexist on same box.
    I still haven't been able to "clean" my machine to ensure a clean install as
    the problems persist after removal and re-installation.
    Do you know of a sure fire way to rid an XP Pro box of ADT (without
    formatting and reloading the OS I mean!)
    Craig
    *Medina, Alfredo
    Re:
    02-02-2003 10:08 PM in reply to: *Mochrie, Craig
    Craig,
    After the uninstallations of both programs, make sure that you remove the
    folders as well. Then, re-start the machine, and install ADT3.3 again. That
    should work.
    Alfredo Medina
    news:9E4AC1D020BDEF8A9667B5F435FB604F@in.WebX.maYIadrTaRb...
    > Alfredo,
    *Services, Tony - Autodesk Professional
    Re:
    02-02-2003 10:28 PM in reply to: *Mochrie, Craig
    Arch Desktop 2i and 3.3 can co-exist on the same
    system.  The following is the install order that must be followed to allow
    these products to function on the same system:
    1. Install Arch Desktop
    2i.
    2. Install service pack 1 for Arch
    Desktop 2i.
    3. Install Arch Desktop 3.3.
    And that should about cover it.  Since you
    have had problems with your previous installations, I would recommend
    uninstalling and reinstalling all of your Autodesk software according to the
    following solution:
    href="http://support.autodesk.com/getdoc.asp?id=TS45252">http://support.autodesk.com/getdoc.asp?id=...
    Tony
    Building Industry Division
    Americas
    Support Delivery
    Autodesk Professional Services
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Craig,
    After
    folders
    should
    work.
    Alfredo Medina
    "Craig Mochrie" <
    href="mailto:craig@selectshopfitting.com.au">craig@selectshopfitting.com.au
    wrote in message
    href="news:9E4AC1D020BDEF8A9667B5F435FB604F@in.WebX.maYIadrTaRb">news:9E4AC1D020BDEF8A9667B5F435F...
    Alfredo,
    of ADT (without
    mean!)
