Autodesk Architectural Desktop 2007 & Prior
*Mochrie, Craig
Message 1 of 12 (127 Views)
AEC crashes ADT 3.3 and ADT 2i
127 Views, 11 Replies
01-31-2003 03:13 PM
I have upgraded OS to XP Pro and have installed ADT2i and then trial of
ADT3.3 Neither program will allow use of AEC objects or dwg templates, I
get a Fatal Error; Attempt to delete AecDatabaseData which still has
registered dependants.
The menu line says could not load requested module "C:\Program Files\Common
Files\Autodesk Shared\AecBase20.dbx".
I cannot open any existing drawings that contain Aec Objects.
Please assist.
Craig.
*Medina, Alfredo
Message 2 of 12 (127 Views)
Re: AEC crashes ADT 3.3 and ADT 2i
01-31-2003 09:07 PM in reply to: *Mochrie, Craig
Crag,
Run a reinstallation of ADT. Select the option named as "Repair AEC loading
mechanism". That might fix the problem.
Alfredo Medina
"Craig Mochrie" wrote in message
news:2283A08792DDC7221F760C0F8C2E2B51@in.WebX.maYIadrTaRb...
*Bromell, Paul
Message 3 of 12 (127 Views)
02-01-2003 01:57 AM in reply to: *Mochrie, Craig
Someone please correct me if I'm wrong because I don't know for sure but I
don't believe that those 2 programs can co-exist on the same drive/machine.
A search through these newsgroups should yield an answer to that.
Paul Bromell - Metalstuff
Files\Common
> Please assist.
> Craig.
*Mochrie, Craig
Message 4 of 12 (127 Views)
Re:
02-01-2003 10:49 AM in reply to: *Mochrie, Craig
Alfred,
Thank you for the suggestion. I reinstalled ADT2i and can now use the
metric aec template, however no AEC applications are loaded. I could not
find the Repair AEC loading mechanism option, is this in ADT 3.3 only? If I
load AecData.dbx by manually looking for the file, same error about
dependants comes up and it crashes again. Also on loading I get a error
that the shortcut has a bad profile in the ADT.arg and that the one in the
registry will be substituted.
Craig.
*Medina, Alfredo
Message 5 of 12 (127 Views)
Re:
02-02-2003 12:33 AM in reply to: *Mochrie, Craig
Craig,
Yes, that option is in the ADT3.3 installation CD. Also, I think the problem might be
caused for trying to have ADT2i and ADT3.3 installed in the same machine. Why don't
you just leave one version?
Alfredo Medina
news:FD3F01D444E2D2A1EFA239B409245581@in.WebX.maYIadrTaRb...
> Alfred,
> find the Repair AEC loading mechanism option, is this in ADT 3.3 only?(...)
*Mochrie, Craig
Message 6 of 12 (127 Views)
Re:
02-02-2003 07:34 AM in reply to: *Mochrie, Craig
Alfredo,
I have only ADT2i on the machine at present. I would like to be able to go
back to a fully functioning 2i before I load 3.3 again. I am reluctant to
try 3.3 again until I,( with the assistance of people like yourself), have
repaired the problem. I would like to know what caused the error in the
first place.
*Medina, Alfredo
Message 7 of 12 (127 Views)
Re:
02-02-2003 10:51 AM in reply to: *Mochrie, Craig
Craig,
The problem might have been caused when you tried to have the two programs
simultaneously. I understand that these two versions cannot coexist in the same
system.
Alfredo
news:C453FE78FFAEE9F172B6568363C27713@in.WebX.maYIadrTaRb...
> Alfredo,
> first place.
*Mochrie, Craig
Message 8 of 12 (127 Views)
Re:
02-02-2003 01:30 PM in reply to: *Mochrie, Craig
Alfredo,
I think you are right, I should not have installed 3.3 with 2, however 3.3
and 2i are supposed to be able to coexist on same box.
I still haven't been able to "clean" my machine to ensure a clean install as
the problems persist after removal and re-installation.
Do you know of a sure fire way to rid an XP Pro box of ADT (without
formatting and reloading the OS I mean!)
Craig
*Medina, Alfredo
Message 9 of 12 (127 Views)
Re:
02-02-2003 10:08 PM in reply to: *Mochrie, Craig
Craig,
After the uninstallations of both programs, make sure that you remove the
folders as well. Then, re-start the machine, and install ADT3.3 again. That
should work.
Alfredo Medina
news:9E4AC1D020BDEF8A9667B5F435FB604F@in.WebX.maYIadrTaRb...
> Alfredo,
*Services, Tony - Autodesk Professional
Message 10 of 12 (127 Views)
Re:
02-02-2003 10:28 PM in reply to: *Mochrie, Craig
Arch Desktop 2i and 3.3 can co-exist on the same
system.  The following is the install order that must be followed to allow
these products to function on the same system:
1. Install Arch Desktop
2i.
2. Install service pack 1 for Arch
Desktop 2i.
3. Install Arch Desktop 3.3.
And that should about cover it.  Since you
have had problems with your previous installations, I would recommend
uninstalling and reinstalling all of your Autodesk software according to the
following solution:
href="http://support.autodesk.com/getdoc.asp?id=TS45252">http://support.autodesk.com/getdoc.asp?id=...
Tony
Building Industry Division
Americas
Support Delivery
Autodesk Professional Services
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Craig,
After
folders
should
work.
Alfredo Medina
"Craig Mochrie" <
href="mailto:craig@selectshopfitting.com.au">craig@selectshopfitting.com.au
wrote in message
href="news:9E4AC1D020BDEF8A9667B5F435FB604F@in.WebX.maYIadrTaRb">news:9E4AC1D020BDEF8A9667B5F435F...
Alfredo,
of ADT (without
mean!)
You are not logged in.
Ask the Community
