Attached is a "fixed" drawing. One of the open Space Objects was misbehaving
in the drawing.
(I had to add a new Space Object so please check so it's correct, see
attached file.)
Hope this helps!
Anna
wrote in message news:4873516@discussion.autodesk.com...
My office has just converted from ADT3.3 to ADT2006. So far this has gone
pretty well, but a user has come to me with a problem and I can't figure out
what it is. She's got one file that she can open and save normally in
ADT3.3, but when she opens the same drawing in ADT2006, she gets:
"INTERNAL ERROR: !dbobji.cpp@6266: eNotOpenForWrite"
I've removed the xrefs, Recovered, Audited, Wblocked, Inserted, every trick
I know to no avail. But the same thing happens every time. If I view the
text window while I run Recover in ADT2006, I see the following:
Validating objects in the handle table.
Valid objects 2190 Invalid objects 0
Validating objects completed.
Creating new ACAD_MATERIAL dictionary
Creating new ACAD_COLOR dictionary
Creating new ACAD_TABLESTYLE dictionary
Used contingency data.
Salvaged database from drawing.
Fixed 14 cross link(s) in entity lists.
Opening an AutoCAD 2000 format file.
Auditing Header
DXF Name Current Value Validation
Default
Door Display Props (LAYER)
eNullObjectId 0
Door Display Props (LTYPE)
eNullObjectId ByBlock
Door Display Props (Color)
Out of range ByBlock
eNullObjectId 0
(these eNullObjectId's go on for quite a bit, covering all kinds of objects)
Then it tells me that it's recovered the draw
ing database, and then I get the Internal Error as indicated above. The
file has been zipped and attached. Anyone have any idea what's happening
here? Thank in advance!
