• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Alias
    Active Member
    pen shaking
    243 Views, 11 Replies
    07-14-2008 01:57 PM
    I have the Wacom Cintiq 21UX with Alia SBP 2. Whenever I sketch the crosshair shakes violently and the line is a few mm away from where I want it to be. Any suggestions on how to make it stop?
    Please use plain text.
    Active Member
    Re: pen shaking
    07-15-2008 10:56 AM in reply to: rideit152
    That's supposed to be Alias SBP 2 . . . if it wasn't obvious.
    Employee
    Re: pen shaking
    07-16-2008 06:04 PM in reply to: rideit152
    That's really strange. When the cursor shakes, makes me think there is some kind of interference affecting the pen's output to the tablet. Is this only happening in SBP and in no other application?
    c.
    Active Member
    Re: pen shaking
    07-17-2008 05:02 AM in reply to: rideit152
    Right. It only does it when working on the Wacom using SBP. My other monitor is running too (clone setting) and it works fine. Also, when I try to select a different tool / color / etc. it doesn't show all the options . . . I have to remember where they are and "blindly" drag the pen to select them. I haven't used it in a while since it's been a pain.
    Employee
    Re: pen shaking
    07-17-2008 05:38 AM in reply to: rideit152
    would be worth downloading SBP 2009 trial version to confirm that this continues to be a problem...
    http://usa.autodesk.com/adsk/servlet/mform?siteID=123112&id=10507445
    c.
    Member
    Re: pen shaking
    07-17-2008 08:17 AM in reply to: rideit152
    Try reinstalling the wacom driver and recalibrating the stylus. I've seen offset problems on Vista which were fixed when I reinstalled the driver. The violent crosshair shifting I've not seen before. What graphics card are you using, are you using a dual monitor? In some dual screen modes there can be a potential for cursor magneting that I've seen in the past.
    Member
    Re: pen shaking
    07-17-2008 08:19 AM in reply to: rideit152
    I see that you are in 'clone' setting. Try 'dual view' mode.
    Active Member
    Re: pen shaking
    07-17-2008 08:37 AM in reply to: rideit152
    tried out SBP 2009 . . . same problem
    Active Member
    Re: pen shaking
    07-17-2008 08:38 AM in reply to: rideit152
    tried dual view . . . actually worse . . . doesn't even recognize the pen on the Wacom
    Active Member
    Re: pen shaking
    07-17-2008 09:20 AM in reply to: rideit152
    i reinstalled the driver and before calibrating the pen everything works okay . . . just a little misaligned. it's when i calibrate the pen that i run into the crosshair shaking. after that happens i just delete the user preferences and deal with the slight misalignment. if i change my seating position and point of view it lines up okay . . . kinda a stupid work-around though. i have a NVIDIA Quadro FX 3400/4400 graphics card.
