• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Alias
    Board Manager
    Re: Project Falcon Technology Preview now available on Autodesk Labs
    02-09-2012 08:35 AM in reply to: ABukowski
    I have been meaning to reply back. Thanks for the conformation that updating your video driver fixed the issue.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Please use plain text.
    Active Member
    ABukowski
    03-12-2012 05:32 AM in reply to: scott.sheppard
    I've got some issues with Falcon's ability to calculate drag correctly, or it's interpretation of model data and drag.
    I can replicate expected figures at low speeds for primitive shapes, but if i place an elongated shape such as a rectangle into Falcon it seems to calculate some areas incorrectly.
    For example, I run a test on a very basic rectangle shape with a curved leading edge.  This gets calculated as having a CD of 0.7 with a drag force of 2947 N.
    The frontal area of the model is 8.925m, but to have the CD and drag being calculated as it is would require a frontal area of around 11.11m, or an air density of 1.5kg/m3, both of which are incorrect.
    Similarly, if the model is rotated before import to requre a 0 degree yaw in Falcon, there are errors in the calculation once again.
    Is it possible to divulge some more information regarding how Falcon interprets the geometry model and the airflow / drag readings so that this issue can be troubleshooted?
    Board Manager
    03-13-2012 06:37 AM in reply to: ABukowski
    Please send me your file, so I team can play with it, and we can be sure we are seeing the same results.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Board Manager
    03-27-2012 08:03 AM in reply to: scott.sheppard
    The team has shared with me that the next release will have accurate (error < 0.001%) front area calculated.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Active Member
    ABukowski
    03-29-2012 03:04 AM in reply to: scott.sheppard
    Thanks to the team for looking at that problem.  Looking forward to the next version; any idea when the next update might be expected?
    Board Manager
    03-29-2012 07:37 AM in reply to: ABukowski
    Not sure - I rarely know in advance. Labs is an agile organization that responds quickly, so we don't require advance notice.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Active Member
    ABukowski
    03-29-2012 07:47 AM in reply to: scott.sheppard
    I'll just check back regularly then.  Looking forward to it!
    New Member
    04-16-2012 10:13 PM in reply to: scott.sheppard
    Thanks for the tips. It can help me a lot. :smileyhappy:
    New Member
    04-27-2012 07:54 AM in reply to: scott.sheppard
    Install Standalone
    Falcon32bit.exe
    2011.0.1.0
    Project Falcon 2012
    on
    Windows XP Pro
    Version 2002
    SP 3
    Pentium 4 3.00GHz
    2GB RAM
    After installation, attempt to run by clicking installed icon... Get the following error
    Falcon Application
    Exception caught whilst running WindTunnelApp: 'pack://application:,,,/WPFOpenTK;Component/Themes/ExpanderTemplate.xaml' value cannot be assigned to property 'Source' of object 'System.Windows,ResourceDictionary'. Could not load file or assembly 'System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The system cannot find the file
    specified. Error at object 'System.Windows.ResourceDirectory' in markup file 'WindTunnel_CFD;component/mainwindow.xaml'.
    Subsequently have to kill WindTunnelApp.exe in the Windows Task Manager.
    Any suggestions?
    Cheers, Simon
    Active Member
    ABukowski
    06-20-2012 01:59 AM in reply to: scott.sheppard
    Is there any word on a likely release of the next update to Falcon?
