• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Alias
    *Matt Dillon
    Maybe wrong newsgroup - Alias = Showcase? Material problems
    265 Views, 2 Replies
    01-15-2010 12:09 PM
    I'm assuming that Autodesk Showcase *used* to be Alias Design... if not,
    read no further.
    In Showcase, I've assigned a png file as a texture map for a material, but
    all of the texture map manipulation controls are greyed out - I can't size
    it, move it, rotate it, link the texture maps between the color and bump
    maps - nothing.
    I've tried this with multiple maps, multiple files - it's always greyed out.
    I can see the maps on the objects after assigning the materials, but I
    REALLY need to modify their UV parameters. Brick usually isn't 2" long...
    Thanks in advance...
    Please use plain text.
    *Matt Dillon
    Re: Maybe wrong newsgroup - Alias = Showcase? Material problems
    01-16-2010 04:31 PM in reply to: *Matt Dillon
    Never mind. I got the answer I needed :-).
    "Matt Dillon" wrote in message
    news:6319335@discussion.autodesk.com...
    read no further.
    maps - nothing.
    Active Contributor
    CadlineSupport
    03-13-2012 02:51 AM in reply to: *Matt Dillon
    Hi Matt,
    What was the solution for this problem please? I have exactly the same issue!
    Many thanks for your help
