• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Alias
    New Member
    Diagnostic Shading section is gone!!!!!!!!!!!!!!!!(Alias 2013)
    894 Views, 6 Replies
    05-13-2012 06:06 AM
    I closed it accidently. But I Don't know where can i find it.....
    Please Help me!!! I got tones of asignments!!!!
    Please use plain text.
    Distinguished Contributor
    Re: Diagnostic Shading section is gone!!!!!!!!!!!!!!!!(Alias 2013)
    05-14-2012 10:01 AM in reply to: b55507
    Object Display/Diagnostic shade.
    BYE
    New Member
    05-14-2012 06:11 PM in reply to: b55507
    yeah i had the same problem, kindof an inconveniance, i even tried to unistall and reinstal but it didnt work either. please help autodesk.. WHERE IS THE DIAGNOSTIC SHADING palette????
    Active Contributor
    05-15-2012 10:20 AM in reply to: b55507
    Try choosing a different workflow under Preferences > Workflows?
    Some do not have the diagnostic shade in the control panel.
    Active Contributor
    05-15-2012 10:22 AM in reply to: b55507
    Also, irregardless of that, top right there is a drop-down that also controls this. It should be on "Default".
    New Member
    04-25-2013 04:56 PM in reply to: KevinDeSmet
    In 2013 toggling to 'default' no longer briings up shaders and visual states docked inside the 'Control Panel'.  Anyways, toggling over to default every time I want to shade would be a pain...
    However, one can now middle mouse drag a shader into their pallete or shelf.  So pull down 'Object Display' > 'Diagnostic Shading...'.  When that window opens you can mmb drag the shader to wherever you like, even your 'Marking Menu'.
    If you can't see the 'Diagnostic Shading...' make sure you have long menus truned on,  Preferences> Menus> Long Menus
    A little on this, you can also customize the settings and create different ones.
    http://wikihelp.autodesk.com/Alias/enu/2013/Help/0124-Autodesk124/0174-Interfac174/0260-Customiz260/...
    When you are done close out the "Diagnostic Shading...' window for a clutter free workspace.
    Member
    05-09-2013 04:32 AM in reply to: jaker277
    Since Alias 2013 my Control panes at all was away. I have to click it manually on Windows Control Panel and it isnt aligned any more on the main screen.
