• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Alias
    Valued Contributor
    Re: Curve Snap tolerance issue - does not really snap onto curve but next to it
    10-02-2012 03:51 PM in reply to: cekuhnen
    That is correct, what you are doing is fine. And, interestingly enough, your screen shot is now appearing in the first post.
    Please use plain text.
    Distinguished Contributor
    10-24-2012 02:09 AM in reply to: JohnDixon8251
    SET DRAW PRECISION to something like 0.85.
    That should do it, or you have a gfx hardware issue.
    02-26-2013 01:12 PM in reply to: ravenzep
    I think also about the Draw Precision value issue, by default Quality Draw Precision = 0.5
    This is too low if you are working in Class A with a single span surfaces / curves, as the previous post said try to increase the value if your computer works.
    But take care about the value, if you check the maximum is 1 but after many investigations please remind about the "exponentiel" value from 0 to 1, also if you put 1 the most of the time 90% it works well... But sometime you will feel your model move slowly and block looks too big ! ! ! My recommendation is to put maximum 0.9 for a nice result.
    Nicolas Caquelin
