• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Alias
    New Member
    aaron.law
    Can I alternate the function of Middlemousebutton and Rightmousebutton?
    121 Views, 2 Replies
    08-09-2011 01:24 AM
    the middle button of my mouse is not comfortable to click.
    so i want to change it with right click button.
    will somebody tell me how could i change them?
    Please use plain text.
    Product Support
    Ruediger-Ambs
    Re: Can I alternate the function of Middlemousebutton and Rightmousebutton?
    08-30-2011 05:04 AM in reply to: aaron.law
    Hello aaron law,
    actually I do not recomment to change these settings,  rather buy a better mouse.
    But if you are insisting to change the settings you can do this in the general preferences unter the tab Input.
    or you can change it under preferences/selection options.
    If you want to change the the Marking menue you can do this by pressing the shift and control button and the left mouse button there is a tap called <edit Marking Menue> select the option box next to it. A new window opens, there you can change what you want.
    BUT AGAIN I DO NOT RECOMMENT TO DO THIS. Just imagine someone else has to work on your computer they will not be able to work with your settings. Or the other way around you are comming to a company and you are supposed to work there, you will not be able to work there anymore, because you are used to different settings.
    I had this kind of experience and we decided afterwards not to hire this freelancer anymore. Because it was too much trouble to get back to normal setings.
    kind regards
    Rüdiger
    Ruediger Ambs
    Senior Product Support Specialist
    WWSS-GS-Premium Support MFG West
    Autodesk, Inc.
    New Member
    aaron.law
    05-12-2012 11:48 PM in reply to: Ruediger-Ambs
    I really do appreciate you answer and kindness,
    thank you very much Rüdiger!
    kind regards!
