• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Alias
    New Member
    Alias Studio Problem Sketching with Paint Symmetry
    228 Views, 5 Replies
    08-27-2008 07:40 PM
    I have encountered a problem using the paint symmetry tool within Alias Studio paint/sketch workflow. When I attempt to use either bilateral or radial symmetry when sketching with any paint brush I experience massive lag.ie. The stroke is drawn onscreen several seconds after I've completed.
    I use a wacom cintiq although the same result is encountered when using the mouse as an input device so I do not believe it to be a driver issue related to the tablet. The problem persist regardless of how small I make the canvas; minimum number of layers ect. I have a reasonably high spec. machine, so I do not expect it to be a hardware resource issue. No other applications are running, so it should not be an application conflict. And finally, I've updated the drivers on everything I can think of.
    If anyone else has experienced this problem and has found a solution could you please advise. Thanks.
    Please use plain text.
    Active Contributor
    Re: Alias Studio Problem Sketching with Paint Symmetry
    08-28-2008 09:45 PM in reply to: andrewrumble
    what graphic card?
    if your on subscription, I would call that in.
    Geez, Thats the reason i dont use photoshop and i never have had that issue.
    Employee
    09-01-2008 12:01 AM in reply to: andrewrumble
    I`ve experienced this with my Toshiba tabletPC, mainly in screen clone mode (using beamer)
    Unfortunately, I was not able to reproduce it regularly and I still suspect it is wacom/nvidia issue.
    I`ll keep you posted if found anything.
    mike
    Valued Contributor
    09-23-2008 05:12 AM in reply to: andrewrumble
    Rereading the original question, I don't see anything about PhotoShop. How did that become part of the issue?
    CarlFrischmuth
    10-15-2008 04:02 PM in reply to: andrewrumble
    ive seen massive lag too but havent found any ways to fix it yet..
    New Member
    10-11-2012 06:19 AM in reply to: CarlFrischmuth
    any solution ? I m having the same issue.
