AutoSketch
Member
fgruber
Message 1 of 12 (145 Views)
positioning objects on the grid
145 Views, 11 Replies
10-04-2002 05:14 AM
When I move or copy an object using the mouse, the object is not snapped by the grid. I see the reason of that: The reference point (the mouse cross) is somewhere in the middle of the object, a position that may be between grid points. This point is snapped by the grid and not the endpoints of the lines of the original object I want to move.
I hate this behaviour of Autosketch 7. In Autosketch 2.0 it was easy to move objects in the grid using the mouse. The only solution I found, is to copy objects over the clipboard, but that is not comfortable.
Can anyone give me a tip?
Ferdinand Gruber
*AngryofMayfair
Message 2 of 12 (145 Views)
Re: positioning objects on the grid
10-04-2002 09:13 AM in reply to: fgruber
Sorry I can't help but I have also noticed this anomoly and IMHO it's a bug
that should have been fixed by now - there cannot be many times at all (none
that I can think of) when you want the 'mouse point' to snap to grid or
anywhere else as it's never the same point twice. What should happen is that
the object's ref point or end point or mid point *should* snap to grid or
any other snap point for that matter, not the mouse ref point...
Just another one of those little bugs that need fixing.... :-(
The only way at the moment to move/copy things accurately is to use the
'translate' command.
An accurate 'drag & drop' translation would be very very nice - come on you
'bug fixers' how about it?
Please?
"fgruber" wrote in message
news:f11559c.-1@WebX.maYIadrTaRb...
> Ferdinand Gruber
*Nolte, John
Message 3 of 12 (145 Views)
Re:
10-04-2002 09:25 AM in reply to: fgruber
Place the cursor over the about point, right click on it, and choose "Move
About Point." Locate the about point on your entity that you want on the
grid, and use grid snap to place it there.
John
*Harvey
Message 4 of 12 (145 Views)
10-04-2002 10:56 AM in reply to: fgruber
John of course is right. And so am I:
Don't use the grid! No need. It just gets in the way.
Use the Transform tools to place objects or entities where you want
them.
Our old friend Paul told us years ago that it's always best to draw
specific entities somewhere on the drawing page and then move them into
position on the drawing in any number of ways using those Translate
tools. I hated to say it but he was right on that one.
He's wrong so many times that sometimes it's hard to guess where he's
right. But we love him anyway.
> comfortable.
> Ferdinand Gruber
Remove bupkis to reply
*Harvey
Message 5 of 12 (145 Views)
10-04-2002 11:01 AM in reply to: fgruber
Here's the thing, Ferdinand. You can just start drawing you entities
anywhere on the page. Untick the Page box in View>Appearance and then
the entire screen is always filled with the "paper."
Now what you do is create any entitiy and move it into position IN
RELATION TO WHAT IS THERE ALREADY! That's the trick. And it's why you
should take a few minutes to see what those Tranform tools do. Ask away
here for any details you need.
You can stand this program on its head with those guys. And it's so easy
to do that in a few days you'll wonder why no one told you before this!
That'll be $10, please. Just forward your credit card numbers.
> comfortable.
> Ferdinand Gruber
*AngryofMayfair
Message 6 of 12 (145 Views)
Re:
10-04-2002 11:04 AM in reply to: fgruber
Agreed.
> them.
But wouldn't it be really nice to be able to drag objects/symbols and have
them placed accurately to any other object/line or symbol without having to
use 'translate' and select 'e' for endpoint or 'm' for midpoint and forget
to select on deselect the 'copy' box/?
All the above could be done with the autosnap function (if it worked
correctly instead of using the mouse reference!) and just hold the ctrl key
for copy as you drag the object....
Heaven! :-)
*Harvey
Message 7 of 12 (145 Views)
Re:
10-04-2002 11:17 AM in reply to: fgruber
I don't get your point here, Angry.
Once you tick the copy box, it stays ticked. The [Ctrl] key with
Move+snap will copy things where you want, won't it? I don't have the
program up now and haven't used it in a while, so I'm a bit rusty on
this detail. And you can always use the MoveAboutPoint for positioning,
if that's reasonable.
But I personally like the use of the snap function with the Translate
tools. It seems to me quite logical and the way a programmer would want
to see it and create it.
One can envision all sorts of changes to this program to make it like
another program, but that's really not the game. The game is to find the
bugs! Not hard with V7. Don't know about V8. V6 is quite smooth for what
it does.
Anyway, woulda coulda shoulda. There would have to be quite a user
groundswell for ADSK to make substantive changes to this low-end
program. So we're stuck with what it does, and it ain't bad for $100. At
least V6 ain't bad!
> Agreed.
> > them.
> Heaven! :-)
Member
fgruber
Message 8 of 12 (145 Views)
Re:
10-05-2002 05:20 AM in reply to: fgruber
Thank you John, I tried at once what you told me and that was a solution for my problem. This way of working is a little complicated in comparison with AutoSketch 2.1 but it works.
I am using AutoSketch at school with 13 and 14 years old pupils and I am sorry that I had to leave release 2 and step up to 7. The reason was, that AutoSketch 2 crashed on our new Compaq Computers. And the only thing of R2.1 that I did not like was the matter, that in this program you must first choose the action you want to do (copy, move ...) and then select the object. I do not know any program with this sequence of actions ... But otherwise that small old program would be the better way for drawing at school than with AutoSketch 7 - it ist too complex.
Ferdinand
Member
fgruber
Message 9 of 12 (145 Views)
Re:
10-05-2002 05:34 AM in reply to: fgruber
Thank you, Harvey for your posting.
Theese are new interesting aspects for me.
Anyway I am surprised of that echo of my posting. It is the first time that I try this newsgroup and it not easy for me to read and to write in English language. I am not familiar with talking about technical and drawing problems in English. Therefore I think the only one, who should get 10 $ (or 10 Euro) is me, due to that hard working ...
Ferdinand
*AngryofMayfair
Message 10 of 12 (145 Views)
Re:
10-05-2002 09:27 AM in reply to: fgruber
Hi Harvey,
Yes the 'copy' box works fine - it's just that I have always found it to
be incredibly easy to forget to use it!
It always seems to be ticked when I don't want to copy and unticked when
i do want to copy. This usually means an 'undo' and then another
translation attempt, this time with the box ticked or unticked...
It just seems to me that since Autodesk took over Drafix and attempted
to make it 'Windows compatible' or whatever, they could have so easily
got rid of this silly tick box and allowed the use of the ctrl key to
copy (during translating) which is common in most Windows software and
is in fact exactly what we do when dragging an object (hold ctrl to
leave the original) so why isn't it the same for the translate command,
or the mirror/align command for that matter?
> want to see it and create it.
Absolutely - the translate function works fine in itself - it's just the
'copy' tickbox I dislike...
What I was trying to say was that for me, if I could select and drag a
symbol and move it to another place accurately using autosnap it would
be even easier than using the translate function - just as there are
always many alternatives with a good cad program - this would be a
useful alternative to 'translate'.
> the bugs! Not hard with V7. Don't know about V8. V6 is quite smooth
> for what it does.
Agreed in general - all software has it's foilbles I guess. AS6 doesn't
have that many and in general it's a pleasure to use - in fact I am
always pushing it's versatility, robustness and lack of high price.
but this *is* my point - IMHO, the reference to the *mouse position*
rather than an object end or mid point when dragging is one big bug!
It's pointless (sorry for the pun!) to use the mouse point position as a
snap reference - it changes depending on just where you have the mouse
when you click on an object to drag it. It would have been far more
useful to use an endpoint or midpoint of the object being dragged so
that it can be dragged and placed accurately in relation to other
objects, or to the grid if folks insist on using it.
It's many years since I used AS2 but from what the originator of this
thread (FG) was saying - that's how it worked in that version and that's
how it should work now.
It's only a minor thing but a nuisance and shouldn't be a huge change -
just a bug-fix patch...
GB
You are not logged in.
Ask the Community
