• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoSketch
    Member
    line distortion
    67 Views, 2 Replies
    05-16-2004 01:31 PM
    After I draw a line or polyline that appears straight, it distorts slightly after changing views. Is this possibly a video issue. I can print the same drawing twice and the results are not the same. The distortion seems to change with different levels of zoom.
    Please use plain text.
    Active Member
    Re: line distortion
    05-16-2004 04:49 PM in reply to: tom smoker
    You might try to see if you can find an update to your printer driver. M
    *Len Rafuse
    Re: line distortion
    05-17-2004 02:41 AM in reply to: tom smoker
    On screen I have had this happen. If you zoom in it should look OK (no jumps or distortions.) If it prints funny, your print driver would be something to update. tom smoker wrote: > After I draw a line or polyline that appears straight, it distorts slightly after changing views. Is this possibly a video issue. I can print the same drawing twice and the results are not the same. The distortion seems to change with different levels of zoom.
