I am using Autosketch 9 and have no reason to upgrade to V 10. Has anyone loaded up Windows 7 and tried Autosketch 9 or 10. And does it work?
Have been running AS9 on XP platform for a long time but switching to new HP with windows7. AS9 appeared to load properly (no weird messages, ect). However, failed to start and gave message "missing acge16.dll file. Checked new computer and, indeed, there is no such file. Any thoughts ?
I just installed AS-10 on a HP Windows 7 Home Premium 64 bit PC with no trouble and I can open any .skf file with one click, AS-10 will start and the drawing is ready to use.
Thanks for the info re AS10. However, my needs for a high quality 2D program are significantly less than they were 2years ago. At this point there are several good freeware programs that will satisfy my needs. If AS9 worked, I would have continued using but not worth paying for AS10. Good luck !
I ran V7 the V8 and V9 on Windows XP then updated with V9 to windows 7 and now 8.1 with the only problem being the selection of an skf file in explorer started Autosketch but did not come up on the screen.
I ignored the problem windows 7 then 8 and now 8.1 as it is the only issue I have found to exist..
I distribute a lot of my drawings in pdf format and find it helpful in the filing system as it helps me find an old file as explorer is a little easier than the browse in autosketch.
I would like to start an skf from explorer but have gotten used to not being able to.
Kevin H
Subsequent to this old post I had found a way of fixing my problem (in this forum) and it worked perfectly after that I then upgraded to windows 8, 8.1 and now 10 with no problems although I now run Autosketch 10.
