AutoSketch
Title block edit
1 REPLY 1
Kingroad
466 Views, 1 Reply
Title block edit
Hi
Attempting to add details in an existing AS10 title block template (using the database fields) the text extends into the next block field. Exploding the title block allows the text to be repositioned but converts the text to a formula. Grouping only makes the block a single entities but the formula is still visible with no text. How can the text in a title block be repositioned without this problem?
Can the formula be hidden and have the database text reappear?
Tony
1 REPLY 1
rjsczupak
in reply to: Kingroad
did you ever get an answer on this?  having the same problem...
thanks!
