AutoSketch
Member
HOWARDGLAD
Message 1 of 6 (1,746 Views)
TRANSLATE
1746 Views, 5 Replies
02-09-2011 11:09 AM
I HAVE SUTOSKETCH 9
WHEN I GO TO EDIT-TRANSFORM-TRANSLATE: I GET IT T O MOVE WHERE I WANT IT, HOWEVER THE ORIGINAL PART OF THE DRAWING IS STILL SHOWING. WHEN I AM MOVING IT AN INCH AWAY IT IS VERY DIFICULT THE MANUALLY DELETE IT.
IT USED TO WORK FINE
THANK YOU
HOWARD
StevenMac
Message 2 of 6 (1,743 Views)
Re: TRANSLATE
02-09-2011 12:18 PM in reply to: HOWARDGLAD
In v10 there's a tickbox that turns off 'make a copy' when you translate, scale, mirror, etc.
Member
HOWARDGLAD
Message 3 of 6 (1,741 Views)
Re: TRANSLATE
02-09-2011 12:35 PM in reply to: StevenMac
AS YOU KNOW I HAVE VERSION 9 -  THIS PROBLEM IS NEW. I  DON'T WANT TO SPEND $250 FOR A NEWER VERSION.
paul.wacko
Message 4 of 6 (1,725 Views)
Re: TRANSLATE
02-09-2011 07:37 PM in reply to: HOWARDGLAD
Look on the left had side of your EDIT BAR and you will find a tick in a box.
Remove it and all will be well.
Paul Jackson
Western Australia
http://www.resolv.com.au
Scott_P
Message 5 of 6 (1,724 Views)
Re: TRANSLATE
02-09-2011 07:39 PM in reply to: HOWARDGLAD
When you select transform a tickbox does indeed show up just below the layers drop-down in the property toolbar, at least that's where it appears on my three 'puters.  Not a new problem, my oldest version is AS6 and I also work with v10.  Same tickbox, same place, though I will admit I have not worked with v9.  When you select transform look towards the upper left-hand corner of the AS desktop.  Should be there.  Make sure it is not ticked.  Move entities 'til you heart's content.  Nice. :smileyhappy:
Member
HOWARDGLAD
Message 6 of 6 (1,721 Views)
Re: TRANSLATE
02-09-2011 08:09 PM in reply to: Scott_P
THANK YOU FOR YOUR HELP
You are not logged in.
Ask the Community
