• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    Active Member
    Xfieldok
    Accepted Solution
    Spline and Fitted Curves pen width
    993 Views, 4 Replies
    01-21-2011 06:54 AM
    I have been happily using spline  and fitted curves with no problems.  Suddenly, they are not responding to a change of line width, can anyone explain what I am doing wrong?
    Please use plain text.
    Distinguished Contributor
    Re: Spline and Fitted Curves pen width
    01-21-2011 01:13 PM in reply to: Xfieldok
    Can you attach the drawing so we can have a look? You may have to rename the file extension to .doc or .bak for the forum to accept it.
    Active Member
    Xfieldok
    01-21-2011 11:28 PM in reply to: StevenMac
    Thank you Stevenmac.  Attached is spline.doc which was renamed from spline.7z.
    The item is in green.  Have tried every which way to change the width to no avail.  I cut and pasted this into another document and it appeared to work, but not in this one.  Any advice gratefully received.
    01-22-2011 02:20 AM in reply to: Xfieldok
    Thank you for the upload.
    You might not be aware that your 'curve' is actually a multi-segment polyline, and not a spline or fitted line? It only looks curved because it's made up of 30+ straight lines (double left-click it and see for yourself).
    Delete it and draw it again with the right tool if need be... however that still leaves the puzzle of why entering in a new line thickness doesn't actually change the polyline thickness.
    Are you aware your drawing is set to a precision of "1. mm". If you want a line 0.05mm thick you need to go into:
    TOOLS > DRAWING OPTIONS > UNITS > LENGTH > DECIMAL PRECISION > change from 1. to 0.01
    Cheers
    Active Member
    Xfieldok
    01-24-2011 07:18 AM in reply to: StevenMac
    Thank you StevenMac.  It was not quite the solution, I am still not sure what is, but you sent me on the right track and I got round it.
    Looking forward to Paul releasing his book.......
