AutoSketch
Member
robertschatz
Message 1 of 5 (1,382 Views)
Sketch9 file conversion to dxf problems
1382 Views, 4 Replies
03-03-2011 08:42 AM
I am trying to convert my sketch file to dxf, however, some will not convert.  r the program has an application-fatal error with program shutdown.
Any thoughts or could someone convert this SKF file.   For reason I have tried to attach but it does not like the SKF extension
Bob Schatz
Member
robertschatz
Message 2 of 5 (1,381 Views)
Re: Sketch9 file conversion to dxf problems
03-03-2011 08:50 AM in reply to: robertschatz
I figured out a way to attach my file. Just change the extension back to an skf file.
StevenMac
Message 3 of 5 (1,372 Views)
03-04-2011 02:03 AM in reply to: robertschatz
Wow, that's a lot of layers. I deleted every one that was turned off and it then saved as a DXF.
Let me know if you continue to have issues (I use AS10 in Win7 32 bit).
Member
robertschatz
Message 4 of 5 (1,349 Views)
03-07-2011 06:39 AM in reply to: StevenMac
Steve thanks for the effort.   Can you attach the file you converted.   Also you mentioned you deleted some layers, can you convert with all the layers I supplied.
Thanks for the help!!
Bob Schatz
Airspace Specialist
Denver TRACON
StevenMac
Message 5 of 5 (1,332 Views)
03-08-2011 11:28 AM in reply to: robertschatz
It refuses to convert with most layers, so you have to keep deleting those layers that are turned off until it works.
Here's a DXF (2007) and DXF (R12)
You are not logged in.
Ask the Community
