• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    Member
    robertschatz
    Sketch9 file conversion to dxf problems
    820 Views, 4 Replies
    03-03-2011 08:42 AM
    I am trying to convert my sketch file to dxf, however, some will not convert.  r the program has an application-fatal error with program shutdown.
    Any thoughts or could someone convert this SKF file.   For reason I have tried to attach but it does not like the SKF extension
    Bob Schatz
    Please use plain text.
    Member
    robertschatz
    Re: Sketch9 file conversion to dxf problems
    03-03-2011 08:50 AM in reply to: robertschatz
    I figured out a way to attach my file. Just change the extension back to an skf file.
    Distinguished Contributor
    03-04-2011 02:03 AM in reply to: robertschatz
    Wow, that's a lot of layers. I deleted every one that was turned off and it then saved as a DXF.
    Let me know if you continue to have issues (I use AS10 in Win7 32 bit).
    Member
    robertschatz
    03-07-2011 06:39 AM in reply to: StevenMac
    Steve thanks for the effort.   Can you attach the file you converted.   Also you mentioned you deleted some layers, can you convert with all the layers I supplied.
    Thanks for the help!!
    Bob Schatz
    Airspace Specialist
    Denver TRACON
    03-08-2011 11:28 AM in reply to: robertschatz
    It refuses to convert with most layers, so you have to keep deleting those layers that are turned off until it works.
    Here's a DXF (2007) and DXF (R12)
