• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    New Member
    LineDrawer
    Problems with the Fill Option
    139 Views, 1 Replies
    10-24-2011 05:08 AM
    I am using the Fill Hatch command to fill a circle and changing that into a solid fill using entities.  My problem is that the solid fill is overlapping the line I used to draw the object.  Is there a way to fill the object and have the line on the edge show?  Thanks in advance for any advice.
    I linked the picture, and it doesn't have a clear line.  If I intensify the line around the fill, you can see the results on the right.  I just want to see a clear border on the object.
    Please use plain text.
    Distinguished Contributor
    Re: Problems with the Fill Option
    10-31-2011 02:24 AM in reply to: LineDrawer
    There's a toolbar called "arrange", which has a button for "move to front" and "move to back".
    After a while sketch will begin to forget what's supposed to be where, then you'll need to practice this method:
    -> Click either the outline object or the fill object to highlight it
    -> go to the layers dropdown bar and re-click the layer it's sitting on
    -> use the arrange buttons to confirm where this shape should sit
