AutoSketch
Problem to save some files in DXF
4 REPLIES 4
975 Views, 4 Replies
Today i had tvelve (12) drawings to convert from .skf-format to .dxf-format (AtoCad2007.dxf)
Ten files was succesfully saved but two files failed.
Every fila are named as SR1201-2xx (-270, -271, -272 ....)
All files are created during the last two montth on the sam computer (Windows 7, 64bit)
I run AutoSketch 10.
A messagebox pops up saying "Error: Failed to save file".
I can't see any differens for these to files.
I also tryed to save sem in .dwg-format with the same negative result.
Have anyone a tip?
4 REPLIES 4
braudpat
Hello
Mysterious !
Maybe I could try with my AutoSketch v9 to generate DWG or DXF !
If you can give us the 2 SKFs files (ZIP format please)...
But I don't konw if my AK v9 can load yours AK v10 drawings ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
pendean
Autosketch forum may be of more help:
http://forums.autodesk.com/t5/AutoSketch/bd-p/107
Usually, when a translation fails, it means there is either an error or an unknown object that does not have a DXF or DWG code equivalent.
in reply to: braudpat
Hello Pat
No you are right you can?t open Ver10-files on a Ver09 program.
I think its a window-system-problem but i dont know how.
Thanks for your interest
Bye, Hans
*Saltsj? Reningsteknik AB*
Can you .ZIP the files and I'll try it.
One guy several months ago had drawings so large they corrupted after a certain file size, his work was unrecoverable.
