AutoSketch
*Jackson, Paul
Message 11 of 20 (229 Views)
Problem: Auto-Highlight
12-02-2001 11:44 AM in reply to: *L, Chris
"Chris L" wrote in message
news:3C085C95.9828B0C0@lakefield.net...
> This feature should also be taken as far as the "Parallel Line" command.
> Imagine, "pulling off" a parallel line just as you do now. But, in
addition
> to the program allowing you to "Snap" it, A dialog box has the current
> location in it and it is HIGHLIGHTED, ready to take keyboard input.
> This can not really replace the offset command in that you need the
> existing "offset" for placing repeated entities the same distance over
and
> over.
Hello Chris
What you are describing above can be done.
I often have the requirement hat an entity needs to be copied and then
repeated OR the identical move repeated on other objects. So, iof this is
what you are asking here are the steps.
Highlight the entity to be copied use the about point and a snap mode (Lock
also) to relocate the entity using [Ctrl] key.
After this the
  • key can be used to repeat the move and copy OR select
    another entity and hit
  • and the identical transormation will occour.
    Until another move is completed the
  • will remain.
    Paul Jackson
  • *L, Chris
    Message 12 of 20 (229 Views)
    Problem: Line Width
    12-04-2001 02:15 PM in reply to: *L, Chris
    Graham Howe wrote:
    (snip) I re-read Ad's terms of acceptance in which they
    > readily acknowledge British law (since I purchased the product in the
    > UK). Under these circumstances and since they are reported to have
    > fixed a load of problems in AS8 then a patch release for AS7 should be a
    > snip and would meet British software product expectations.
    COOOL !! oops...shhhhh ! (when your attorney gets them to send the patch,
    send me a copy, you know, for "demo" purposes)
    Wait... I better send this in code:
    (sesoprup "omed" rof ,wonk uoy ,ypoc a em dnes ,hctap eht dnes ot meht steg
    yenrotta ruoy nehw)
    Chris
    > Graham Howe mail: (ghowe@mcb.net)
    > Home Web site: http://www.homepages.mcb.net/howe/
    *L, Chris
    Message 13 of 20 (229 Views)
    Problem: Circle "Radius"
    12-04-2001 02:18 PM in reply to: *L, Chris
    Ya,
    dia/2.....
    That does get old after 20 or so holes... Think of us poor Machine
    designers ! We don't use bubble gum to hold stuff together! We use a lot
    of holes and then BOLT things together.
    Just gimme the stupid DIAMETER box already !
    be happy,
    CL
    Graham Howe wrote:
    > In message <3C09B39C.2D72C270@lakefield.net>, Chris L
    > writes
    > >I think it is fair to say that the use of diameter far outweighs
    > >Radius. Who pulls a ruler or measuring device across a hole and tells
    > >you its dimension by Radius ?
    > Agreed but I just enter dia/2
    *Tall, Stephen
    Message 14 of 20 (229 Views)
    Problem: Line Width
    12-04-2001 05:51 PM in reply to: *L, Chris
    steg
    > yenrotta ruoy nehw)
    !thgir ti teg nac I fi ees s'tel os edoc siht htiw krow ot dah I ecnis elihw
    a neeb s'ti ,ah ,ah, aH
    ,sdrageR
    (noinU teivoS eht fO) llaT nephetS
    *Tall, Stephen
    Message 15 of 20 (229 Views)
    12-04-2001 05:59 PM in reply to: *L, Chris
    I agree, radius is okay for corners etc, but when it comes to doing bolt
    holes just about everyone I know works in dia's. Mind you it doesn't affect
    me that much 'cause I created a (sorry for about the bad pun comming...)
    (w)hole load of symbols for standard holes, that way whenever specifiying a
    hole, it is always consistent with previous designs. Also it means that I
    don't have to remember all our standard over-sizing rules.
    Anway, what's wrong with a bit of bubble gum holding stuff together. Pilots
    used to repair bullet holes in their fuel tanks with some gum and the gum
    wrapper!
    *Howe, Graham
    Message 16 of 20 (229 Views)
    Problem: Line Width
    12-05-2001 12:11 AM in reply to: *L, Chris
    In message , Stephen Tall
    writes
    >steg
    >> yenrotta ruoy nehw)
    >,sdrageR
    I never knew you guys were fluent in the Manx language! What you say
    makes sense so its now over to Autodesk to make us all even happier ;o)
    *CL
    Message 17 of 20 (229 Views)
    12-05-2001 02:38 AM in reply to: *L, Chris
    Stephen Tall wrote:
    (snip) "bolt holes just about everyone I know works in dia's. Mind you it
    doesn't affect me that much 'cause I created a (sorry for about the bad pun
    comming...) (w)hole (YOU BAD!) load of symbols for standard holes, that way
    whenever specifiying a hole, it is always consistent with previous designs.
    Also it means that I don't have to remember all our standard over-sizing rules.
    Ya, thats why I didn't create any symbols for holes. Usually I have to work with
    an existing part first. So you measure it and make it on the fly.
    da.da.da /2 enter da.da.da /2 enter da.da.da /2 enter da.da.da /2 enter
    you get the idea.........
    > wrapper!
    I think when your in the sky you'll do anything to be able to walk on ground
    again if your in trouble. heck, I betcha I could come up with SPIT thick enough
    if the situation required it !
    CL
    *CL
    Message 18 of 20 (229 Views)
    Problem: Line Width
    12-05-2001 02:46 AM in reply to: *L, Chris
    Maybe it's time for: ralhsA, daCobruT, potksedorP, ro egdE-diloS.
    Well, right after Miller-Time anyhow !!!
    > writes
    > >steg
    > >> yenrotta ruoy nehw)
    > >,sdrageR
    *Selzer, Gerhard
    Message 19 of 20 (229 Views)
    Problem: Line Width
    12-05-2001 05:10 AM in reply to: *L, Chris
    Okay, you basic Enigma dabblers,
    are you trying to find the mysterious code to find
    the unanswered question of the 12 corrected items in R8
    or Greig ?nekcwuzfua nehcseornroD ehcilnneam sad mu
    (Thought I add some of the original WWII problems but
    was very careful not to use "V"8 to provoke bad memories
    for Graham and Stephen and implying a similar attempt
    by the new release.
    It is bad enough to see V2 being used here with nostalgia
    without impunity and without any sense of history.)
    Gerhard ;-)
    > > writes
    > > >steg
    > > >> yenrotta ruoy nehw)
    > > >,sdrageR
    *Selzer, Gerhard
    Message 20 of 20 (229 Views)
    Problem: Line Width
    12-05-2001 05:44 AM in reply to: *L, Chris
    (Thought I add some of the original W.W.II problems but
    by the new release.
    Gerhard ;-)
    > > writes
    > > >steg
    > > >> yenrotta ruoy nehw)
    > > >,sdrageR
    You are not logged in.
    Announcements
    Need installation help?
    Ask the Community
