• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoSketch
    *kb
    Point of Origin...?
    103 Views, 7 Replies
    03-14-2000 10:53 PM
    hi all,
    I am trying to create a lanscape drawing that has an origin of the real
    world lat. lon., is this possible in AutoSketch? The plot plan was easy,
    but I would like to make the origin lattitude/longitude accurate so I can
    drop points off a GPS. {Oh, I have AS R5}. Thanks in advance.
    Please use plain text.
    *Selzer, Gerhard
    Re: Point of Origin...?
    12-15-2001 02:15 AM in reply to: *kb
    kb,
    Must admit that I don't quite understand the question.
    Is what you are trying to accomplish something similar as per enclosed
    sample?
    http://www.lib.utexas.edu/maps/middle_east_and_asia/mazar-i-sharif_85.jpg
    Gerhard
    BTW, great job opportunities for landscape architects over there.
    kb wrote:
    > hi all,
    *KB
    Re:
    12-17-2001 06:46 AM in reply to: *kb
    Well, not quite that elaborate...nor that far away...
    I would like to make the origin (latitude, longitude) ie (45.mmm.sss,
    52.mmm.sss) or something like that... What I am really looking for is an
    easy way to drop points on a "plot plan" {locate a pond and it's watershed
    on my property}. If I could set the origin to the actual "earth" position,
    it will be an easy matter to locate points using GPS coordinates.
    Ground measurements are next to impossible due to "geographic features", ie
    hills, trees, brush,...
    If I am way off base... please let me know or if there is a better way to do
    this.... Thanks again for your help
    "Gerhard Selzer" wrote in message
    news:3C1B9354.1598E03C@bellsouth.net...
    > kb,
    > sample?
    > Gerhard
    > kb wrote:
    > > hi all,
    easy,
    can
    *Jackson, Paul
    Re:
    12-17-2001 08:39 AM in reply to: *kb
    Hello KB
    You can change the origin on your drawing from DrawingOptions > Scale.
    However this is in sheet coordinates therefore you will need to divide your
    figures by whatever your scale is.
    Place a known coordinate in East and North ETC... in the boxes both divided
    by the scale and as negative values.
    To insert points use absolute coordinates as X and Y coordinates.
    Paul Jackson
    *Selzer, Gerhard
    Re:
    12-17-2001 10:11 AM in reply to: *kb
    KB,
    Paul, the old pro, obviously solved the problem.
    On the other had, faced with a similar problem in our area,
    I would contact the Palm Beach County tax office with the
    property ID number and order the latest aerial map on a disk
    zoomed in to a proper scale.
    (Maybe these days, I might need FBI clearance first.)
    Would that not work as an appropriate reference basis for
    additional info you might want to add?
    Gerhard
    > > kb,
    > > sample?
    > > Gerhard
    > > kb wrote:
    > > > hi all,
    > easy,
    > can
    *Jackson, Paul
    Re:
    12-18-2001 08:49 AM in reply to: *kb
    Hello Gerhard
    A few of our local authorities here in West Oz do what you have stated with
    AutoSketch, bringing in aerial maps to check the roads and drawings.
    Probably to track rogue Crocks and Koalas before they get into residential
    areas.
    Paul
    news:3C1EA5B6.8C32F2F9@bellsouth.net...
    > KB,
    > Gerhard
    an
    watershed
    position,
    ie
    to do
    > > > kb,
    > > > sample?
    > > > Gerhard
    > > > kb wrote:
    > > > > hi all,
    real
    > > easy,
    I
    > > can
    *Selzer, Gerhard
    Re:
    12-18-2001 12:24 PM in reply to: *kb
    Paul,
    I did not talk about the other aerial maps the Chamber of Commerce
    uses to check daily tourist traffic at local bars & restaurants.
    I meant the other stuff were it is being verified if any trees have
    been removed, any pond filled in or any shed or house addition has
    been added without a permit since last year's property assessment.
    Are you still using old issues of National Geographic as you data
    base?
    Gerhard
    Paul Jackson wrote:
    > Hello Gerhard
    > areas.
    > Paul
    > > KB,
    > > Gerhard
    > an
    > watershed
    > position,
    > ie
    > to do
    > > > > kb,
    > > > > sample?
    > > > > Gerhard
    > > > > kb wrote:
    > > > > > hi all,
    > real
    > > > easy,
    > I
    > > > can
    *Jackson, Paul
    Re:
    12-19-2001 09:02 AM in reply to: *kb
    Yo
    My maps are what Moses used when he built the arc ?
    PJ
    news:3C201686.FA8AAB4F@bellsouth.net...
    > Paul,
    > base?
    > Gerhard
    > Paul Jackson wrote:
    > > Hello Gerhard
    with
    residential
    > > areas.
    > > Paul
    > > > KB,
    > > > Gerhard
    (45.mmm.sss,
    is
    > > an
    > > watershed
    > > position,
    features",
    > > ie
    way
    > > to do
    > > > > > kb,
    enclosed
    > > > > > sample?
    > > > > > Gerhard
    > > > > > kb wrote:
    > > > > > > hi all,
    the
    > > real
    was
    > > > > easy,
    so
    > > I
    > > > > can
