AutoSketch
Line width 1 much to thick on polylines, but ok on simple lines
5 REPLIES 5
tomte-da
1072 Views, 5 Replies
As you can see in the attached Fig.21.jpg all pliylines are much too thick. Changing them to simple lines would make them as narrow as thow shown.
The layers have line width 1 - "Dünnste (1)".
Each polyline has an explicite line width of 1 now, but that does not change anything.
I am using Autosketch 7 in Windows XP.
Any idea haow to make the polylines as narrow as the simple lines?
Thank you in advance!
tomte
Tags (2)
5 REPLIES 5
tomte-da
in reply to: tomte-da
An uggly workaround: Exploding ("Aufloesen") of all polylines. But I can not beleave that this is necessary ... tomte
StevenMac
Right click and edit the polyline width until it appears the same as a sketched line?
tomte-da
in reply to: StevenMac
The polyline is already as thin as possible ("1"), there is nothing to change via edit.
Only the _sketched or exploded_ lines having thicknes "1" are really thin.
tomte
StevenMac
Polyline thickness goes below 1.
Fred9002
I seem to remember that AS7 didn't have real line widths, just device (e.g. printer/monitor) pixel widths which was worthless and confusing.  I'd try avoiding numbers ("1" or whatever) and just set everything to hairline.
