• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    *donwb
    Insert from PDF file
    147 Views, 1 Replies
    01-20-2010 04:21 AM
    Windows XP, AS7
    I'm trying to copy part of a PDF file drawing and put it into Autosketch.
    I use Adobe's snapshot feature which puts the selected part of the PDF
    onto the Windows clipboard.
    From there I can insert it in my AS drawing using Edit/Insert Object and
    select 'bitmap image'.
    That works OK, but the problem is that the inserted drawing is a "whole"
    entity, bounded by an enclosing rectangle
    and it's individual parts cannot be edited, neither can it be "exploded".
    Is there any way I can transfer the required part of the PDF in a fully
    editable format.
    I imagine this is a common problem and any help would be welcome.
    donwb
    Please use plain text.
    *Nick Van Laar
    Re: Insert from PDF file
    01-20-2010 09:35 AM in reply to: *donwb
    That bitmap that gets inserted is exactly that. A .bmp, an image, there is
    nothing vector about it. PDF's by definition are un-editable in the
    strictest sense. What you need is a program that will convert pdf to dwg or
    some other editable vector format. Try BING (or google). This also depends
    on the pdf, some are actual vector graphics, while others are simply an
    image saved as a pdf.
    Another option:
    DoubleCAD XT Pro has a feature called TRACE that will create raster graphic
    (pictures) to vector graphic (CAD) tracings*.
    *mileage may vary
