Right click on the about point. Uncheck the fourth entry: Scale About Here.
This menu is the only access to this command, and it often gets checked
accidentally.
Rod
"Len Rafuse" wrote in message
news:415be3f8_2@newsprd01...
> There must be a setting. My AS 9 rectangles stretche the same as
> versions 8 and 6.01.
> zingher wrote:
> > Often it is necessary to stretch a rectangle (or other entity) on only
one side. For example, the left edge should stay fixed, the right edge
should move further right, and the center-point ("move-about point") should
move halfway to the right.
> > Under AutoSketchv9, for a pre-existing rectangle, handle-pulling the
right edge causes symmetric stretching. Both the right and left edges both
move outward, and the center-point ("move about point") stays fixed. This is
NOT the necessary one-sided stretching.
> > Could this be related to some setting, such as Drawing options,
snap-to grid, etc?
> > By contrast, when I use the rectangle tool to draw a new rectangle,
and immediately do handle-stretching, then the stretching is one-sided.
Unfortunately this does NOT work to stretch a pre-existing rectangle.
> > Also by contrast, under ASv8, handle-stretching does provide
> > I have tried to approximate one-sded stretching by handle-pulling
symmetric stretching followed by moving the entity. However this makes it
very clumsey achieve the required alignment & size.
