after having filled
two chambers and
a pipe between
with red color I took a gif picture for an animation.
Then I need to empty the pipe and take the next gif for the animation.
Because Polylines are much too thick I drew a multiline rectangle over the portion to be emptied.
Into this rectangle I try to fill either nothing or white, but in both cases Black is filled in instead.
How can I optically "empty" that rectangle?
Only sketching quality is needed for the animation.
Solved by Fred9002. Go to Solution.
Solved by StevenMac. Go to Solution.
As you found out you can't have white, but you can have another shape inside a shape.
This will allow you to control what is shaded.
Thanks. Most of these things were head-scratchers for me sometime back and it's nice to be able to try to help.
