AutoSketch
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Frage zu Autosketch Release 2.1. mit Windows NT
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
363 Views, 5 Replies
07-11-2000 06:39 AM
wenn wir mit dem Mauspfeil auf den Werkzeugkasten gehen, dann erscheint die Schutzverletzung "Sketch verursachte eine allgemeine Schutzverletzung in Modul Sketch.exe bei 0090.5306". Wir hatten dieses Problem früher schon mal und mittels eines Leitfadens konnte der Fehler behobenw erden. Leider haben wir uns diesen Leitfaden nicht gemerkt - bitten höflichst um entsprechende Info zur Behebung unseres Problems. Danke.
*Smith, Harvey
Re: Frage zu Autosketch Release 2.1. mit Windows NT
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-11-2000 07:13 AM in reply to:
WG
From http://www.freetranslation.com/
If we go with the mouse arrow on the tool box, the
protection injury appears to "sketch caused a
general protection injury in module sketch. exe in
0090.5306". We had this problem earlier already
once and by means of a clue, the mistake
behobenw was able to ground. Unfortunately we
did not notice
ask ourselves this clue - most politely for
corresponding information to the Behebung of our
problem. Would thank.
Anybody?
did not notice
Anybody?
*Pescher, Harald
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-11-2000 10:47 AM in reply to:
WG
Das Update Release 2.1 c2 Patch bei Autodesk runterladen und installieren,
sollte helfen.
CHANGES CONTAINED IN THIS PATCH
Editing and Drawing
o SmartCursors and Help cursors now work on NT.
o The Change Origin tool can be used on NT.
o Pattern Fills will not cause a Domain SQRT error message to
be displayed.
o The Curve Edit tool no longer accepts non-curve objects.
o The line cursor displayed with the Polar Snap tool is more
accurate.
o When more than one drawing is being edited and you switch
from one drawing to another, any active drawing or editing
tool is now properly canceled.
MFG Harald Pescher
WG schrieb in im Newsbeitrag: ef2a216.-1@WebX.SaUCah8kaAW...
sollte helfen.
Editing and Drawing
be displayed.
accurate.
MFG Harald Pescher
WG
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-18-2000 05:13 AM in reply to:
WG
Danke für die Antwort, aber wir wollen keine neue Version, wir wollen mit der gleichen Version 2.1. Release weiterarbeiten. Es gibt einen Leitfaden für die Behebung des Problems, auf einem unserer Rechner funktioniert das Programm auch, wir wissen nur den Leitfaden nicht mehr. Im voraus Danke für Ihre Hilfe.
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-20-2000 03:13 AM in reply to:
WG
Das Problem ist der smart cursor. Im Sketch-Verzeichnis gibt es eine sketch.ini. Diese lädt man in einen Editor und ändert unter "Settings" den Wert SmartCursor von 1 auf 0. Jetzt werden leider die Erklärungen zu den Icons nicht mehr angezeigt, aber darauf kann man verzichten, wenn dadurch das Programm wieder läuft. Übrigens: ich bleibe auch lieber bei V2.1. In den neuen Versionen gibt es viel Mist!
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-30-2000 06:38 PM in reply to:
WG
Das Update ist nicht wirklich ein Update, sondern ein Patch (=Fehlerbereinigung).
Es wird lediglich die alte Sketch.EXE gegen eine neuere ausgetauscht.
Bei uns lief das Programm unter NT4SP6 anschließend ohne diesen Fehler einwandfrei.
Man kann mit diesem Patch eigentlich nichts falsch machen.
