AutoSketch
Active Member
gregmacp
Message 1 of 3 (306 Views)
File Save As suddenly freezes AutoSketch 9
306 Views, 2 Replies
04-02-2011 06:44 PM
I have been running AS9 since it came out, after running prevous versions all the way back to Drafix. I switched to Windows & on a new machine about 6 months ago and about a week ago I began running into a bug that freezes AS9 when I try File SaveAs. The program will not respond. I have uninstalled AS9 and re-installed from the disk. Any thoughts would be appreciated; I can't work without being able to convert a dwg to an skf and back. Thanks.
Active Member
gregmacp
Message 2 of 3 (297 Views)
Re: File Save As suddenly freezes AutoSketch 9
04-03-2011 10:05 AM in reply to: gregmacp
Thanks to other posts I seem to have solved this problem. Steps:
Uninstalled AS 9
Ran CCleaner multiple times
Used regedit to eliminate any AS related items
Restarted the computer
Re-installed AS 9
Hope it continues to work.
Active Member
gregmacp
Message 3 of 3 (268 Views)
04-18-2011 02:03 PM in reply to: gregmacp
I posted that I had solved this problem (FILE-SAVE AS causes AutoSketch 9 to freeze and require a force quit) but it has come back. I'd love a working solution if anyone has one. I wonder if it is an issue with Windows 7, though I had been running AS9 on this machine for about 5 months before the problem came up.
You are not logged in.
Ask the Community
